DirtyD
FIXED IT!!!!!
The small bolt that clams the shift linkage to the threaded rod for the gears came out and lost...I will find one to fit...
So I installed fdb brake and clutch levers and the brake side is great the clutch side is kinda tight..not real tight....but tight and it will not loosen and when I kicked into first gear and let off of it..the bike does not shift...what could this be...I left all the lines in stock position so I know its not kinked....
Thanks
Sent from my EVO 4G using Tapatalk
Thanks
