http://www.cartestsoftware.com/fz1/images/pol05.jpg
Is your lever arm pointed forward like the picture. I only ask because when re-assembling the clutch cover it’s possible to get the shaft for that lever out of position as the cover is put in place.
When you pull on the clutch lever on the bars does it seem like the lever at the clutch cover is moving, mine moves 5/8” if I measure at the u-bracket that holds the cable end.
