delbert
Wizard
Hi guys
Came back from an 80 mile run, bike running perfect , stopped for 20 mins then started up and she was only running on three cylinders .. limped home and left it till the following day ,started her up and running as normal then cut out and won't restart, now the cooling fan runs at low speed with ignition on and when you flash the headlamp the lamp dosnt work but the cooling fan speeds up, other warning lamps in the cluster are showing up dim , also the right flasher makes the fan work , I'm looking for a bad earth /wire but am not ruling out a faulty cluster , as the reset buttons work intermittent too .. are the clusters plug and play ? As I have the immobiliser lamp in mine being a UK model ,, any thoughts guys ?
Thanks .... I have also replaced the multiplug in the left side of the nose cone as it played up some time ago but has made no difference
