roguevfz1
Got the carbs back together after having them cleaned (I didn't take them apart- pulled all the jets out, tops off, slides out & my buddy soaked them in a sonic bath, blew all the ports out & checked everything over, said they looked good. I know I took a shortcut there but didn't wanna go through al the springs & attachments this time.) & put new bowl gasket's & o rings on all the jets & 1 choke plunger that had the end broken off that attaches to the #1 carb that the previous owner rigged with a hanky plate & zip tie. New plugs, fuel filter, air filter was nearly new, drained the radiator & runnin 50/50 distilled water & white vinegar for a good flush while I sync & adjust the carbs.
I bench set the mixture screws @ 1 turn out & didn't touch the idle speed cable screw at all. It ran pretty good @ around 1k after warming up before I pulled the carbs. I haven't fully adjusted the cable ends @ the carbs as the service manual says to sync the carbs 1st, left that for after. I also need to get a angle screw driver to set the mixture screws Please suggest which 1 is economical & works well!
It started right up with full choke after I cycled the fuel pump a few times & made sure I saw fuel go into the new fuel filter. When I started to let the choke off, it seemed like idle was low so I turned the adjuster a bit to get it to idle around 1k. But then when I turned the throttle grip a little bit, it either died or did some popping out the exhaust. Started it again & it revved a little with a twist then stayed up around 3k so I shut it down. Now it won't allow me to twist the throttle at all. What's the next step? I will say that only riding it twice, I didn't notice how much the grip twits to get to full throttle, but now it only twists about 1/5 of a turn before it hits the stop. Seems like I may have either something binding the throttle cables @ the carbs or I'm just not used to how short a throw this bike's throttle has. Both cables @ the carbs have the nuts run all the way back to give it as much play as it needs & there's virtually no play in the grip.
Thanks in advance for any thoughts.
