spyd3rm4n
I recently picked up a 04 FZ1 that's been sitting a long time. Previous owner started to fix it by installing new spark plugs and a new generic amazon/ebay fuel pump, but abandoned the project when he realized the carbs needed to be pulled.
Carbs were clogged (pilot jets blocked completely!) so I removed them and got the bike running. It starts and idles perfectly, and I can rev it out just fine in neutral. I went to take it for a ride today and it was fine, but after a few minutes it started bogging badly whenever I gave it throttle. It's sputtering and struggling to accelerate, then eventually the RPMs climb and it revs out just fine. Then it ran fine for a while, then the problem came back off and on.
I disconnected the fuel hose inlet at the carbs and when I turn the ignition on, the fuel pump easily runs and pumps fuel so I don't think that's the problem, but I guess it could be possible. The lines aren't kinked either. The airbox looked fine though I still need to check for any obstructions between the filter and carb inlets.
I didn't adjust the TPS but went through the diagnostic steps and when I reconnect the TPS connector with the ignition on the tach needle is bouncing erratically from 5000-6000 rpms. Could this be causing the issue? What else should I be looking at? I still want to remove all the spark plugs to confirm their condition and check the coil connections.
