jingksed
Thinking about buying a set of Shogun sliders. My only reservation is the length of the puck...3-inches seems kinda short. Anyone gone down with these and if so, how'd they work?
Well you don't want the sliders to be too long either to the point where they will act as a leverage point and do further damage to the bike. If they stick out at least an inch beyond the frame, which is what you're trying to protect, then the Shogun's should be fine. I don't know what price you can get them for, but as mentioned the T-Rex sliders are a great value.
Tony, what you want to measure is what points the bike will contact the ground. The best way to do this is with a 4'x8' piece of plywood or drywall. Slide it up against the tires then lift the sheet to see what hits first and what will hit second. (helps to have a friend hold the bike upright while you lift and measure) Measure from the frame out to the fascia of the plywood and add a bit for coverage and grinding of the puck. While T-Rex appears to be long, I found it to only be about 10mm longer than I'd have picked. This left me a bit concerned about the standard Shogun sliders being a bit short. I think Shogun makes longer ones but I couldn't find them at the time.
