Stuuk1
Hi all,
My name is Stuart and im another Uk member to join what looks like a fantastic forum!
Im not new to forums and am a member of many including a certain SV forum (as I have previously owned two Sv's).
I recently bought a 2006 fazer from a good fiend of mine, the bike is in pretty good condition and any other little bits are going to be put right in the coming months, these are tiny things like stone chips, corroded bolt heads, nothing major! Although gave the bike a huge de-grease the other day as it appears to have never been done before...
My mate has done some great modifications to the bike and will post up a list of whats been done below with some pictures I got my girlfriend to take on her posh camera...!
Anyhoo, look forward to meeting you all and also testing your knowledge from time to time when I get confused about something
Oh, almost forgot, just fitted some brand new Battlaxe 023's front and rear and they are awesome!
Modifications:
Full Akrapovic exhaust system
Fixed opened secondary throttle butterflies to give better/quicker throttle response
Increased airbox intaketo allow more air in
Re-routed wires around the frame instead of through the air flow hole freeing up more air for the engine
FCE - Fuel Cut Eliminator as described at the top of the page
Power Commander III
Ignition Module - controls ignition timing, adds more power and smoother throttle response when combined with PCIII
Factory Pro Velocity Stacks
custom map for the PCIII + IM with catering for all the above power mods
All that takes the the rear wheel horsepower from the standard 129-132bhp to an estimated 152-154bhp (i have not dyno'd it but am going off dozens of identical setups that have). If you were to go off figures direct from the engine (brochure listed figures) that would be from 150 to probably 182-185bhp so more than the R1 engine it originally was but with more mid range grunt. The gen 2 FZ1 takes the engine out of the 04-06 R1, de tunes it and gives more midrange with a lower redline. I have given all that power back, and then some!
Cosmetic and handling extras:
Speedking rearsets
Gold Pazzo Levers to match forks, with red switchers to match body
Custom blacked out screen with matching red surround
Black headlight covers that velcro off for night riding
Tilted down bars
Cut down the exhaust by 5 inches and powder coated black for increased rumble, nicer look to match the frame and also so it doesn't look like such a large bazooka
Powder coated black pillion pegs and frame slider extenders
Removed centre stand to reduce weight and improve looks
Frame sliders
Lower cowling
Custom small tail tidy
Smaller plate
Mini indicators on back, blackout indicators on front
Heated grips
Modifications:
Power Commander III
Speedking rearsets
Tilted down bars
Frame sliders
Lower cowling
Smaller plate
Heated grips
