The August issue of the magazine features a super-standards comparison test, with the Kawasaki Ninja 1000 , Suzuki GSX1250FA and Yamaha FZ1.
More...
More...
the FZ really does have a weird peaky curve
That ninja is a very fun bike to ride.
Mind going into more detail, if you have indeed rode one, I'd like to get some real feedback. Thanks.
Now if you had the bottom end of the Suzuki and the top end of the FZ1 you would have the perfect bike.
Well I recently rode both the Z1000 and the Ninja 1000. Both bikes are geared nicely and the fueling is spot on. Compared to the FZ1 they are less "peaky", with real useful power in the mid-range. I didn't get to really wring them out in the twisties, but the handling seemed no worse than the FZ1.
My 03 Zed had really good FI, even better after the PC3. It was carb-like for the most part. I've been struggling with the FZ1, the closed-to-open part of the fueling has been difficult to get use to. One thing that has really helped, though, was pulling the baffle from the Mivv pipe I have (no cat)... seems like it was making so much back pressure that it was hard to get a smooth throttle response, pulling it softened things up a bit and now going from closed-to-open throttle is better and less abrupt (hope this makes sense). I think I'm going to try modding the baffle a bit (if you have ever seen the Mivv baffle, it is super-restrictive in the way it's shaped) and see if I can get a compromise between a bit less sound without so much back-pressure.
I am thinking also that having someone dial in the TPS may help. Chances are the bike never got the right dialing in from techs and so the fueling is not perfect. I have heard this helps many bikes.
I like the all-black Ninja 1000. Just needs better pipes.
What mods have you done to the FZ other than the pipe? Consider an FCE (fuel cut eliminator) from Ivan, smaller flies and a PCIII. "Closed to open" throttle issues are typically a result of the deceleration fuel cut off combined with the factory fueling and secondary throttle fly opening parameters. The FCE cures the throttle snatch. Another option in the works is a reflashed ECU which may solve many of the FZs issues in one shot. Waiting on the results of that one (see Hellgate's thread http://www.998cc.org/forum/gen-ii-tech/11514-fz1-ecu-tuning.html)
Overall, read up on this site and the other. The "closed to open" throttle issues on the GenII are well discussed as are the fixes.
I'm in Silver Spring, MD BTW riding a heavily modded 06. Wonderful throttle but it took some $.
I take magazines with a very large grain of salt. Is the '11 FZ1 throttle perfect? No. Is is terrible? No. It's a good B+ throttle. I have a feeling the '11 ECU is just fine for 99.99% of riders.
I have found if you read the bike mags carefully you can come up with a pretty accurate appraisal of what the machine is like. If you distill MCN, Sport Rider, Motorcyclist and Cycle World in the US, along with a couple in the UK press you can come pretty close as to the good points and bad points. There have been some bikes I've stayed away from from what the tests show. It's way better than just reading the manufacturer's web site, but obviously not as good as test riding a machine which isn't always possible.
If the throttle is B+, good for 99.99% of riders I think most people would say 'problem solved'. Anything can be improved but sometimes it just isn't worth it unless you are fanatical about it.
