FZ1riderNY
Moderator
So taking the steering head and clip-ons off is pretty simple. 1 bolt on each side clipping to the forks and one bolt underneath that bolts the clip-ons to the steering head.
I do have a problem though. The spacing between the forks and the steering rod is different between what I bought and the standard GT250R. I will have to buy the lower as well. That or I will need to drill and tap the existing steering head to put the risers and bar on. That, of course, would be my best option. I am no machine shop though and I am afraid I would not get everything straight.
I'm thinking that it's gonna be a bad deal all around with that head, even if you get the lower. You would need to have the same front wheel and spacers from the other bike as well in order for the brake calipers to line up. It may be that this problem up top will work it's way all the way down. By changing one thing up top will have you changing everything top to bottom. This is only if the space from side to side is different as well which is what Eric was talking about I believe.
