FZ1riderNY
Moderator
Looking really good Brad. Nice job! Has she ridden the bike at all?
Nope. I wont let her touch it untol it is lowered and bars setup for her. I know her to well. If she is uncomfortable the first time we have a lesson she will get turned off. I am am guessing, minimum, two weeks.
On that note... VA_RIDER, can you recommend an OEM parts outlet? I have email 3 different companies requesting quotes without a single reply for a week. Guess I am just going to haver to make those long distance calls.
What're ya looking for?? We always got all of our parts from Hyosung directly...so I don't know how much help I can be there.... are there no local Hyosung dealers that could order parts for ya?
Received the steering head, risers and bar from the GT250 model. $160 for all together. Much better than other options like after market adjustable clip-ons.
I think I am going to try doing all the work myself. It will be a new experiance for me. I am going to take the oprtunity to drain the oil from the forks and replace with a slightly heavier weight oil.
I think I am going to have to order a few cables to reach the higher bars but I am going to hold off on ordering until I have everything installed.
Can you just cut the bolt off, and get a new one, then when you replace it put it in from the other side?
Question Brad? If the distance is different in that direction, what is the difference in distance between the two forks for each? If you buy the lower, you might run the risk of either too much space for the front wheel or not enough space depending on how the forks measure before and after. Bummer though!!
