Gee3po82
pulled rear wheel to have a new pirelli angel Gt tire installed by cylcle gear. After getting new tire /rim back from cycle gear, I decided to install oem rear pads from a local dealer since i had to pull the caliper anyway. After installing the new pads i noticed the pads were dragging against the rotor. The oem yamaha rear pads were defiantly thicker than the EBC organic pads i removed. So, I thought i'd give the bike a good ride and the drag should go away. didn't happen, still dragging!.. is the caliper piston sticking or did cycle gear switch the spacers to the wrong side of the wheel?.. Does anyone know if the thicker spacer should go on the left or right side of the rim?. both are flanged on the 07 gen 2 BTW.
Thanks for any advice!
