2007 FZ1 Specifications
Admin
Administrator
Staff member
  • EngineLiquid-cooled, 20-valve,DOHC, in-line four-cylinder
  • Displacement998ccBore and Stroke77 x 53.6mm
  • Compression Ratio11.5:1
  • Maximum Torque10.8kg-m (78.2 ft-lb) @ 8,000 rpm
  • Fuel Delivery45 mm Mikuni throttle body fuel injection
  • LubricationWet sump
  • IgnitionDigital TCI
  • Transmission6-speedFinal Drive"O"-ring chain
  • Suspension (Front)Adjustable inverted 43mm fork
  • Suspension (Rear)Fully adjustable link Monocross
  • Brakes (Front)Dual 320mm discsBrakes (Rear)245mm discTires (Front)120/70 ZR17Tires (Rear)190/50 ZR17
  • Length2,140mm (84.3")Width770mm (30.3")Height1,205mm (47.4")Wheelbase1,460mm (57.4")Rake / Trail25° / 109mm (4.3")Seat Height815mm (32.1")Dry Weight199 kg (437.8 lbs)Fuel Capacity18 litres (4 imp. gallons)
  • Colour(s)Deep Metallic Blue, Metallic Black
