DonnieBee
I have the following parts available. The first person to PM me has dibbs on a part.
Ignitor Assembly $75
Starter Relay with fuses and mount $30
Starter overide relay$30
Tip over relay $20
Fuel pump relay $50
Sidestand switch $30
Neutral Switch (new)$30
Clutch switch (new) $30
Wiring harness $100
Rectifier $30
Swingarm relay $30
Fuel pump $50
Carburetor boots set of four $50
OEM complete braking system front and rear (includes lines, calipers, pads, master cylinder, actuators, mounting hardware, rear tension bar) $100
Ignition coil (new) $70
Ignition coil $30
Throttle cables $30
Choke cable $15
Front sprocket $30
Cener stand with mount hardware $30
Sidestand with mount hardware $30
Front Fender $30
OEM seat $80
Front Axle $10
Rear Axle $10
Water pump $30
Cooling fan $30
BIG STUFF:
Swing arm (silver) $100
Frame (silver) $200
OEM Headers and pipes to mid $30
Engine $400
All prices do not include shipping, nor will they on any deal
All parts in excellent condition.
Engine runs perfectly
Not a wreck. Just a part out.
Frame available with clear title ($100 additional)
Tip over relay $20
Fuel pump relay $50
Wiring harness $100
Rectifier $30
Swingarm relay $30
Fuel pump $50
Ignition coil $30
Throttle cables $30
Choke cable $15
Front sprocket $30
Front Fender $30
OEM seat $80
Front Axle $10
Rear Axle $10
Water pump $30
Cooling fan $30
BIG STUFF:
Frame (silver) $200
Engine $400
