SETH46
Yeah everythin on the read out was done on that Dyno, same place, same guy, same gear.Might not hurt to throw some more fuel in there at the 100% throttle column at lower revs. Will you hurt your engine if you leave it like it is? Hard to tell, but since I do see that it riches up at the top end you might be ok. Still if it was my bike I wouldn't want it running that lean on the bottom end. What map are you using?
I do have to say that looking at your dyno run there it seem sto be extremely lean and it may be more a function of the O2 sensor that was used than anything else. If you look at the stock A/F ration then that's more or less what you want yours to look like (probably a little leaner). Do you know if that stock A/F ratio was done on that dyno using the same O2 sensor as well?
I'm using a map from the Duken Pack off the other site.
Using a STAGE 3 map by JonDaddy82 (everythin mod'ed but standard headers)
Might use the Dukes Perfection Map again, much richer fuel throughout the map, especially low down.
Seth
