07 FZ1 Axle Nut Size
Getto
And you will need a 19mm allen head for the front tire removal.
Or the old method of taking a spark plug socket and using the reverse end of it. Most have a 19mm end. Take out the little rubber grommet that captures the top of plug. Then take a 3" extension and insert again reversed into the socket opening. Most have a 3/8" drive socket at the bottom to connect the extension.
The getto way of taking off the front axle.
