v-petn
I did this a long time ago but it wasn't for the snatch, it was for surging in the 3k - 4k RPM range. Turned out mine was set out of spec a little at 14 so I bumped it to 18.
The one you set is the actual TPS. The secondary controls the flies. If you have no flies, modded flies or zip-tied flies, you need not bother with setting the secondary because it will not make any difference.
Not sure what flies are... if my bike is stock, just exhaust, filter etc then do I need to do the 2nd tps?
