Red Line
True or false: It's safe to jack up with some foam under the exhaust manafolds to prop up the front wheel for removal?
Oh wow. Lee, did you make those two brackets that are attached to the jack?? I need to get a set of those!
You can even skip the jack if you still have the center stand installed. Prop bike up on the center stand. Have someone sit on the passenger seat and front wheel will come off the ground. Prop some 2x4 or 4x4 under the headers and you're good to go. Of course I would looses the front axle before lifting it...
