Deftone
Just received a set of Tusk grip heaters for my '07. I've got the heaters installed on the bars and the grips back on and I'm about to install the hi/off/low switch.
I know you can wire these directly to the battery, but I understand you can wire them to the ignition as well so the battery won't drain and the grips are only on when the ignition is on.
Has anyone done this? What's the best place to connect the "+" to?
I'm thinking about using the horn mounting screw for the ground wires. Is this ok?
Threads? Links, Pics? Just looking for the best way to install.
Thanks for any tips!
