Hail
Moderator
The Givi side cases come off pretty quickly and if you get the PLXR mounts those can be removed quickly as well. Just leaves some small brackets behind that are hardly noticeable.
*Note: take a look at the attached picture and you'll see what's left behind when you remove the quick release brackets. I have circled the bracket attachment points for reference.
How much is the set of Givi cases with mounts?
