PapaGeno21
So I noticed the filter is quite a lot longer than stock. And because of that, I can't get my normal oil filter strap wrench on it due to the header pipes being in the way.
So my genius brain that I posses came up with a great solution.
What I did was take the rivet holding this part of it together, and drilled it out so its just a pin I can remove. Now what I do is pop out the pin, open up the wrench and go around the filter, pop in the pin and viola, you can use it again to tighten the filter.
Reverse the process to remove the wrench.
I may not be the first to do this, but the thought popped into my head while trying to get it on there and I figured I would post it on here. The pin will not fall out as its tight, and then there is pressure against it anyways when you are using the wrench.
Here is the rivet pin part that I drilled so I can just pull out the pin.
