- Thread starter
- Admin
- #61
FZ1inTX
Adminstrator
If you're going to LED's make sure to get an electronic relay as well to replace your stock flasher relay.
Not sure if you've done pod lights, but if so you'll run into my current issue w/ the pod lights and front LED turns causing a load issue. It can be solved by using Magic Blinkerss from CustomLED though as I found out today.
Can't wait to see pictures...
Thanks! In my quote, he does mention that he is including the new relay that corrects all of the issues and works with any combination of incandescent and LED lights. :tup: I do have the LED pod lights installed.
Thanks for the tip on the Magic Blinkers in the event it doesn't all work!
