LOL! The video shown uses an adapter design (my Version 3) that I developed in 2007 and superseded in 2009 with V4.23. It uses a 2004-2008 R1 shock,
not the 2015. Not mentioned in the video, it requires displacement or removal of the EXUP motor and angles the shock ~7 degrees more vertical which changes the effective spring rate. It did however place the nitrogen reservoir to front to eliminate clearance issues (see photo below).
The Post #2 photos do not show the repositioning of the voltage regulator with the stock bracket 'turned upside down'. In reality, the bracket cannot be installed 'upside down' without modification. The bracket supports the plastic battery compartment. Remove the support and the plastic will be stressed from vertical vibration. Also, the rear brake reservoir attaches to the bracket. The mounting flange will now be on the other side. Ty-wraps anyone?
In an effort to combat ignorance, first look into the overall process and goals of swapping the stock GEN II shock. Overall, the first consideration is the strength of the spring to accommodate the riding load.
- The original GEN II (2006) was designed for typical riders in 220#+ range with moderate passenger accommodation. The steel stamped shock was used to reduce cost given the R1 frame template and use of a redesigned swing arm and linkage. The spring rate was 685 lbs/in.
- Yamaha engineers quickly realized that the spring rate was too strong for the target market which was typically less than 200#s with little passenger riding. The 2007 thru 2015 rate was set at 587 lbs/in which is still quite strong for a 200# rider but accommodates a passenger.
- Load effectively increases when the motorcycle is driven into a turn at high speeds. Track use requires a stronger spring.
- Preload adjustment is not a substitute for proper spring rate or linkage based height setting.
Second, the damping action of the shock absorber is related to the load and proper spring rate.
- Compression damping is related to the amount of movement (height of bump or hole drop) and speed. It primarily serves to limit the amount of upward momentum applied to the frame.
- Rebound damping relates to reducing oscillation (pogo stick) when the spring returns from the compression phase.
- See #3 above.
- The 'inexpensive' GEN II OEM shock does not have adjustment for compression dampening.
- All shock action force relates to the particular load which is being compressed. The shock is designed for the particular weight of the motorcycle and load.
So, any replacement of the stock GEN II shock must first consider use of the right spring and second, a similar weight motorcycle. The R1 spring and shock combo is a good starting point as the GEN II, when stripped of some accoutrements, is relatively close. The proper spring force will allow preload adjustment (approximately 20% of overall travel) for standard ride height and sufficient travel to minimize bottoming to extreme conditions. It should be noted that there are other suspension issues i.e.: ride height, steering head angle, trail, etc. which will be touched upon later.
ANY MODIFICATION TO ANY ENGINEERED PRODUCT MAY CHANGE ASPECTS OF PERFORMANCE, SAFETY AND/OR RELIABILITY. STUPID IS AS STUPID DOES.
The end goal of swapping shocks on the GEN II is to affect ride quality and performance. Also, for most sentient beings, there is consideration of value: gain vs. cost and simplicity. On the high end of that spectrum, an Ohlins shock designed for the GEN II is likely the best alternative. Springs can be ordered for the particular rider's weight and riding style. Production quality is extremely high with adjustments and fit. However, not all people are willing to spend approximately 20% of the overall worth of the machine for a rear shock.
When I purchased a new 2007, my butt told me that it did not like the tar strips on the PCH. Cornering feedback on tight turns was tentative. What was the best alternative? Good used R1 shocks were plentiful at a low price point. The R1 shock was the next level of performance and quality from the OEM GEN II. Since both motorcycles shared many parts, why not?
The '04-'08 R1 shocks share the same connection template: bolt diameter and bushing width. The shock series has a significant number of spring weight alternatives (stock '04-'06 good to 180#, '07-'08 to 220#s, accessory to 260#+). However, the eye-to-eye length is shorter than the GEN II. An adapter would be required as shortening the dogbone to recover lost ride height would affect the constant ratio of compression force severely. Also, consideration of the placement of the nitrogen reservoir (the OEM shock has none) in regards to the under-slung voltage regulator was required.
My first design efforts used the R1 shock along with the upper R1 mounting clevis (see photo below). The clevis is required on the R1 because of a different frame mounting design and could potentially serve to provide a ride-height adjustment on the GEN II. I ended up with an adapter (3rd generation) which moved the upper eye downwards and rearwards, with the reservoir to the front clearing it from the voltage regulator. Unfortunately, the exposed stud and bolt from the clevis interfered with the EXUP motor. Luckily, Yamaha had provided an opposite side mounting hole on the motor and only wrenching and a little cutting of the tank mount was needed to provide clearance. However, the adapter changed the angle of the shock in relation to the linkage swing and effectively increased the spring rate. Neither issue was a drop dead, but a better design could reduce installation to a simple 'bolt-in'.
After many drawings I came up with adapter Version 4.23. This placed the upper shock eye in a direct line with the frame flanges and cured both the spring rate issue and need to modify the EXUP position. Tried it on the GEN II with both the '04-'06 and '07-'08 series shocks (different springs). It was a winner. To this day it is the least expensive no-mod, bolt-in GEN II shock swap/upgrade alternative.
I explored adapter design using the '09-'14 series R1 shocks. The eye-to-eye length is shorter and reservoir placement higher than the earlier series. Furthermore, the spring rate significantly stronger (to heavy for anything but constant passenger riding). It was not worth the design effort.
I was enthusiastic when the 2015 R1 spring hit the streets. It appeared to be a good alternative with a spring rate in-between the '04-'06 and '07-'08 series (see chart below) and has a bit longer travel. Given that only the upper eye bushings were a mounting problem, I set about making it fit. I even trimmed the lower rod threaded area to allow lowering the GEN II rear. I could not find a good (inexpensive) and competent means to modify the voltage regulator tray to fit the nitrogen reservoir, voltage regulator and maintain the other functionality (supporting the battery and mounting the brake reservoir) without significant modification. Fabricating a different tray was not economically feasible for a saleable product. It should be noted that the wiring harness for the GEN II does not allow a lot of voltage regulator repositioning and reducing the exposure of the cooling fins to airflow may reduce reliability and longevity. While I could do a Version 3 type adapter with a modified clevis to put the reservoir forward, it was going to be a tight fit requiring more upward adjustment to the lower eye (possible). Not worth the hassle to do it right.
A short observation on the use of the V4.23 adapter. With a proper spring and preload setting, it raises the rear of the GEN II approximately 19mm or 3/4". This is within the range of kickstand and rock-stand use with a 190/50 tire. Go with a bigger rear tire and spacing plates will be needed.
The raising of the rear effective changes the angle of the steering head by ~1/2 degree. This causes the bike to lessen turn-in effort (a good thing IMHO) and increases the risk of handlebar oscillation at high (120mph+) speeds, not a good thing. The GEN II stock is 25 degrees of angle. The R1 is 24. The R1 comes with a steering damper. Tank slap is dependent on many factors including tire condition and inflation, rider position, etc. I suggest that you consider this issue when using the adapter.
The use of R1 ('04-'06) lowering dogbones (see photo - cut-out provides lower eye clearance) can reduce the ride height to stock or lower it further. I use R1 front forks which are shorter than the OEM GEN II and like the lowered center of gravity and flat foot on the ground (I have a short inseam) when stopped. Also, I ride with a 180/55 tire on an R6 wheel (GEN I spec). However, I fabricated an adjustable kickstand and jettisoned the rock-stand.
So, in conclusion, use of the 2015 and later R1 shock is not as simple as it sounds. Better to buy an FZ-MT 10 which comes OEM with a comparable unit.
Early Version 3 adapter.
Shock upper-eye to reservoir and eye-to-eye length comparison: 2015-2008-2009.
Spring Rate Comparison
Rear height reducing dogbone.
