My SeatConcepts front seat finally arrived. Installed and rode about 40 miles in comfort! 4 things I like: rear is wider and flat, foam is much more comfortable, grippy top is grippy and no sliding into the tank.
Hey, what did you use to clean your headers?Installed my new to me slip-on
Pics with exhaust sounds
Cleaned the headers:
Tested to see if soft saddlebags would fit over mounting plate for top case so I wouldn't have to modify the mount:
Waiting for Daddy to come by so I can do the test ride with new pipe and bags mounted and test my modified ciggy box mini dv case to see if I still have vibes in the cam or need to just accept it as a helmet cam.
Thank you.I can’t tell you what he used, but fine steel wool and WD-40 works great for me. Soak the steel wool with the WD and wrap it around the pipe and scrub it in a circular motion around the pipe..
What do you use the GoPro mount for that is on your Gas Tank? Do you mount a camera on it?Installed CRG Arrow bar end mirrors. Covered old mirror mounts with Lennon Mirror Eliminators. Replaced cracked windscreen with Puig Dark Smoke screen. Happy with updates
View attachment 27428View attachment 27429
I see the mount on your bars, but this looks like a GoPro camera mount on the tank:
Is that part of the phone mount setup?
When you mount it there, what sort of footage are you getting? Do you have an extended arm to get it high enough to see past the bars and gauges?Ahh yes sorry. I do place my GoPro on it. Also have a mount in the tail.
