Ok then I've found a very good company in the UK called Black Shadow that actually make quality wavey rotors at very good prices. Only £40-50 more than the China cheapo's
Here's some info from the site...
Brake Vibration (Causes and solutions)
Many riders confuse rotor warping, or warped rotors, with a condition called DTV (disc thickness variation). DTV occurs when a vehicle brakes are serviced and the brake rotor has runout in excess of 0.08mm . This runout causes the pads to contact the rotor when the vehicle is being driven "off brake" and after 3-4000 miles( Sometimes Much less), a thin spot develops on the rotor. The rotor runout itself does not actually cause a vibration. It is the effect of the thickness variation of the brake disc or brake rotor under braking that causes pulsation. Even small thickness variations such as 0.012mm or 0.0005" will exhibit itself as pulsation. A warped rotor is a very rare occurrence and in many years in business, we have seen no genuine cases of warped brake rotors.
The general guideline is that if the vibration happens immediately after install, there is a quite severe runout problem that needs looking into. Brake discs or rotors should be mounted on flat smooth rust and dirt free hub flanges without the use of coppaslip which includes small particles which have the same effect as dirt. Remember that even a small particle of 0.001" under the rotor surface can cause a deviation of 0.005 at the pad contact point.
An Example
Your wheel turns once every 1.9mtrs thats 842 turns per mile or
842104 turns per 1000 miles. If there is any runout Irregularity, on every turn of the wheel,
a minute amount of material is taken off the high spot as the caliper does not retract the pistons fully
each time the brakes are applied. In Time this will wear a thin spot altering the Parallel flatness
which then CANNOT be remedied, only by stripping and Re-machining the Rotor
Even a particle of DUST can measure .0005"
If the vibration happens after 3-4000 miles and sometimes Much less, this is a clear indication that DTV has occurred which is not a warranty condition. The only solution for this is to remove the brake rotor, have it re-machined if possible, or replace it with a new rotor.
Every case of "Warped Discs" reported to us has been caused by NOT checking the Run-out when fitting.
Here's the web page
http://www.blackshadow-uk.co.uk/index.html
I think I will buy from Black Shadow. Each rotor disc is tested and serial number stamped.
They do replacement rotors for most of the top brands too.
Thoughts guys?
Cheers Delta.
