Ssky0078
Hi guys,
It's been awhile since I've been on. I've been super busy and just grinding away
So, the current issue I need help with is I keep getting a coolant leak from the top (center of the bike). The bike will just start spitting coolant out and at one point I had it towed to the shop. The shop took it apart and said the top hose had blown itself completely off. The tech said he had removed the other end of the hose about 3 weeks before when they did the valves, plugs and cam chain tensioner. He said he didn't remove the end that had blown off.
I did an oil change a week ago and the oil filter was slightly different than previous filters, same part number but different inside (it had circular punched out mesh rather than the regular loose wire look).
Today I parked the bike and again it's leaking coolant, not blowing out but a good steady drip and probably let out maybe up to 2 ounces. It seems to be coming from the center of the bike again.
What is there in the system that could be creating the pressure to blow a hose off?
Do I need to just replace all hoses, thermostat and possibly radiator to make sure this stops happening? (this is my daily driver and I don't have any other transportation, other than a bicycle)
The bike has 34,000 miles on it, 29,000 by me in the last 15 months. I've done regular oil changes, chain/sprocket, valves, coolant was done at 18,000 miles I think.
