BDazzler
I am curious who has and uses throttle locks and if so what brand, price and how well they work. Are you satisfied with it? Does it do what it should. How is the quality? Are there any unforeseen drawbacks?
I just installed the Throttlemeister throttle lock on my 2007 FZ1. It was easier than I expected. You simply remove the stock bar ends. Now slide the plastic friction ring under the end of the hand grip. Then screw in the adapter into the end of the handlebar. Finally place bar end in place and screw in the acres to hold it on. Now you need to test the throttle lock to ensure the throttle is freely moving when Throttlemeister is in the 'off' and has enough friction to hold the throttle in place when turned to 'on'.
At this point, there is a trial and error process of finding the right thickness of washer, shim and spacer combination. After the correct mix is found, unscrew all the parts and reassemble the parts with blue thread locker so things don't vibrate loose or become loose due to the twisting that takes place to operate the Throttlemeister.
Throttlemeister on 2007 Yamaha FZ1 - YouTube
