INFORMATION FOR THOSE WHO ARE NEW to PLASTI DIP
I have done the rims on my car, the more your ride, the more layers you need to put on. I have a guy who has had plasti on his rims for over a year...no pealing no anything, through the winter, salt all....still good. He used 5+ layers though. I am going to do the carbon fiber pattern with plasti on my windscreen, to match the carbon fiber pattern on my mirrors since I have a carbon fiber helmet. I am also going to do the to black plastic covers as carbon fiber from plasti dip. Then probably do my rims blue with a silver metalizer over the top. I will be doing a minimum of 5 coats of the blue and 4 of the metalizer since motorcycle rims are more exposed to the elements than car rims.
the thing to remember about plasti dip is it has that tact feeling to it. So if you are going to put it on your tank where your knees are, your knees will grip it and won't slide, so if that's what you want....then it's perfect. Another thing....plasti dip becomes even more durable (hard) after 5+ days because it has time to "cure" once it's cured, its a lot lest tacty...it's not shiny smooth, but lint and cloth etc, wont stick to it at that point. If you are using it on your windshield, i would let it "cure" before riding at dusk and getting it plastered with bugs lol.
I love the stuff. I am about to plasti the mid consol in my car because it's starting to peel. And I am am thinking about doing the whole car for the winter, it's excellent for keeping salt off of your car. If not the whole thing...I am definitely doing the bottom.
FYI, Plasti dip is rated to 312 degrees Fahrenheit so I may do my Yoshi pipe metalic blue too!
(the yoshi tag has a little rust on it) If anyone else considers this then it is a MUST that you let it CURE, if you do it before it cures then it will not be durable.
