WAYamFan
New Member
I've had the ECUnleashed remap done recently and wanted to share some findings - is anyone still interested in this thread?
ECUnleashed is an amazing option that most newer bikes 06+ absolutely need to remove the emissions regulations and retards the manufacturers put on all new bikes. it transforms your bike into a new machine and you'll never regret it. my second job is with a dyno tuner and we do these daily
A couple of questions for you PK . . .
What's the complete list of mods on your bike?
Why should you need the FCE after the reflash? ECU unleashed has always claimed that the reflash elminates deceleration fuel cut. Some reports have shown that the fuel cut is still there after the reflash which would be a major disappointment on the GenII . . .What is your experience?
Hi Eurban,
List of Mods: Arrow Headers, Leo Vince Slip-on, AIS Blocked, Opened Airbox, K&N Filter, Longer Velocity Stacks (Factory Pro), Shaved Secondary Butterflies (CD), Flashed ECU, PCV
The re-flash has removged fuel cut. there has been a definite improvement.
Cheers,
PK![]()
I'm confused . . .In your earlier post you say that the FCE (Ivan's fuel cut eliminator) was great?
Overall, your dyno results look similar to plots I have seen for similarly modded bikes with the stock ECU and proper mapping on the PC. This is not to say that what you feel on the street would be the same particularly with the removal of gear based restrictions.
The pluses for the ECU reflash (in theory anyway) in my mind . . .
Biggest:
Removal of gear based power restrictions
Removal of deceleration fuel cut
Lesser:
Base fueling closer to ideal, tailored (at least somewhat) to the mods on the bike
Ignition parameters tweaked
Secondary throttle plate parameters tweaked
It would be nice to obviate the need for any aftermarket goodies. It does appear that the PC(V or III) will still be needed for fine tuning, which IMHO wouldn't be a deal breaker. If hardware like the FCE or ignition module are still needed then the reflashes value is majorly diminished.
PK,
Thanks for the clarification. As Whittlebeast mentioned some others who have had the flash done (and requested the removal of deceleration fuel cut) did not end up having the fuel cut removed. This was verified in testing and at the time ECU unleashed was unable to correct the problem. Hopefully they have corrected the issue now.
For clarity sake I would suggest that you not call the reflash mod to the ECU, FCE. The mod to the ecu removes the deceleration fuel cut. In the Fizzy world, the FCE is a product made by Ivan (to remove the deceleration fuel cut) and it will just confuse your readers!
