oldschoolsdime92
I have a rattle or jingle ( sounds like coins being shaken in your hand) that I can't find ! Anyone ever experience this ?
Sounds like the top triple tree area, but I've disassembled and reassembled and looked at microfishce over and over to make sure everything is put together / torqued correctly. Is there a fix for the pads rattling?
^^^ that sounds very plausible. Im not understanding why you must take off the front wheel. Wouldnt it be easier to leave the wheel on and keep the lower half of the fork solid, so it doesnt spin when rotating the top?
Sounds like the dreaded vibe of the small plastic section above your gauges,if you look there are some fix`s on this site,while riding put a hand on this section to see if stopsI have a buzzing sound in the same area around the same rpm. The only thing i dislike about the bike so far. Sounds like its at the top of the tank or by the triple trees Like you said. Probably completely different than yours mines a second gen.
