Big Day Today! I wish I could have done more but it seems that the "little" things are the ones that take up so much time! Was down by 7:30am and got back up at 4pm. I got a lot accomplished considering I was working "solo" today. Richie felt it necessary to sleep til noon! I will list all the things I got done today and then go right into the photos so as not to bore anyone with my senseless ramblings.
Installed the Coolant Reservoir
Mounted the Battery Box/Tail Section
Reinstalled Shock Reservoir, ECU, Relays, Fuse Box
Cleaned Radiator and mounted both fans
Greased and mounted rear wheel
Installed OEM Tool Kit
Greased and mounted front wheel
Cleaned EXUP Valve
Broke down Valve Assembly, Tapped last 3 holes, Sanded all parts, painted assembly, greased EXUP Valve, assembled unit
Changed Oil and Filter
Unassembled and cleaned rear tail light
Installed tail light section
Installed front fender's rear section, followed by front fender
Removed and cleaned EXUP Servo
Cleaned and vacuumed top of engine
Cleaned Old Chain for front sprocket removal tomorrow
I'm exhausted just looking at this list! Okay, now for the mountain of snapshots from today in order........
Coolant Reservoir Installed
Battery Tray/Undertail installed
Shock Reservoir installed...
ECU, Relays, Fuse Box installed...
Almost ready to install
Radiator cleaned and fans painted and reinstalled.....
Rear wheel installed.....
Half a "roller"....
OEM Tool Kit installed....
Front wheel installed....
EXUP Valve Cleaned and de-carbonized
EXUP Assembly disassembled and sanded....
I sanded in between the pulley halves so that there won't be any undue wear on the EXUP Cables.
EXUP Cover painted and drying...
EXUP Valve lubed with Copper Grease Anti Seize...
