RadGuard radiator guards .
fitting instructions are as follows -
Radiator Guard fitting Instructions
Supplied: 1 x Radiator Guard
1. Remove the original plastic guard from in front of the radiator.
2. Remove the bolt that holds the radiator on at the bottom.
3. Slide the new RAD GUARD in front of the radiator.
4. Hook the RAD GUARD over the top of the radiator and under the black plastic flaps.
5. Line up the bottom of the RAD GUARD with the same mounting point that the bottom bolt originally came from and then
bolt it back into place using the original bolt.
6. Fasten the bolt securely.
Nice website Bro! I have been looking for the preload adjuster tabs. I'm definitely picking those up. Thanks! Happy Holidays.
