harrisch
Hey guys,
A while back i had a retrofit done by Rabbitman109 on the forums - i tried private messaging him but i dont know if hes off the forum or what but the message wouldnt go through.
Anyway...
Ive been having an issue with my HID retrofit.
I know he used a kit from the retrofit source - everything had been working flawlessly until this past weekend where i noticed that the light no longer fires. I had an issue with this once before where i just had to replace a relay so i figured that would be the problem, however once i put a new relay in, when i push the starter, the bike starts and immediately cuts out then starts and immediately cuts out, over and over again as i hold the starter button. while this is happening the headlight bulb flickers but never ignites.... if i remove the relay, the bike starts fine but theres no headlight obviously.
Does anyone know what the issue could be here? Seeing as the bulb seems to flicker im assuming that the bulb must be fine.... and the relay i replaced and that didnt fix the problem - so im thinking that this just leaves the igniter? and that must have gone bad?
any insight anyone has would be greatly appreciated.
also random side note - does anyone know the screw specs for the screw that goes in the center of the top cover of the airbox (the screw infront of where the air sensor plugs into the top of the box)
Thanks in advance for any input![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Anyway...
