Intermittent Electrical issue
Arrrgh2001
Hi all,
I have an '02 with an odd issue, any help is appreciated.
Intermittently when the signals are on for a short time, the entire dash starts flashing, including the odometer and clock,
It stops when the signal is turned off,
This has been like this since purchase 1 year ago, until yesterday when the flashing dash continued after the signal was turned off.
I turned the entire bike off and back on, flashing continued, since i needed to get home, I drove off and the flashing stopped.
I deployed the high beam and flashing started, but stopped when I switched to dim.
Otherwise it runs great, starts fine.
Thanks in advance
Are any of your turn signal bulbs burnt out?
I know that when one goes out that the indicator flashes at a rapid rate instead of the normal rate, it is possible some sort of short is causing what you are experiencing and you might need to replace a bulb?
