fz1skull
my bike dies sometimes when I come to a stop if you turn the key off then back on it starts. it will run flat out at any speed but only dies when you let off the throttle. I talked to service tech at the yamaha dealer but as usual they want to run complete test of every possible thing from fuel to relays. I suspect it has something to do with the idle circuit, because when you turn the key off and back on you hear the fuel pump cycle. It will also do this when on the center stand when you wick the throttle hard and let off. then sometimes it won't do this at all for days if anyone knows what this might be I would be greatful for any info. Thanks...
