Chandler
I just took my airbox off to get to the ECU. I noticed my flies are open a little. Last time I had the air box off they were closed. Does anyone else know of any similar issues? I am curious to know if my flies are stuck. If they were, I feel like I would notice a lack of air in some RPM ranges so I don't think that is the case. maybe the servo is messed up? Also I noted the stacks had a tacky film on them and on the flies (Assuming into the injectors as well). What is this caused by? I haven't let bad fuel sit in it and in any case is the air box not an old dirt carb.
The servo cables that connect to the exhaust are disconnected because I put on a cheap slip on. Is that related?
Thanks!
Thanks!
