MIKEMINNOW
New Member
Before you spend money on a Power commander, EXUP error codes and block off plates think about a ECU flash from Ivans. The things Ivan has done with his ECU flash is unreal. Things included in the flash are:
Radiator fan now comes on 189 degrees
Throttle response is noticeably much better
No more backfires on decelerating
Remove your EXUP illuminates error codes
No error codes.
Flash allows you to take full advantage of your add ons
Check out Ivans website for all the details
Follow the 2 steps prior to shipping ECU. They were easy to do. Total turn around time was about a week.
This the best thing I've done to my FZ1. You can feel the difference immediately.
THANK YOU IVAN
No error codes.
THANK YOU IVAN
