where do I buy blank keys?
Toph
Hello everyone..
I own a Gen2 FZ1/s 2008 and have been looking to buy blank uncut ignition keys with the transponder chip.
I have the red master key and only one black ignition key.
I lost the black one today, but after much hunting, managed to find it again.
put the sh*ts up me..haha..need to get some sprare ones.
any suggestions?
I can hear you all now sayin'..go to a main dealer...but are there cheaper alternatives?
Dustin
Hi there,
You can buy blank transponder keys on eBay and I believe there is a method to program them yourself, as long as you have the red key.
I found these instructions for the R1:
Insert the red key into the ignition and turn it to "ON". The immobilizer indicator light should come on for 1 second and then go off.
With the red key still in the ignition, start the engine.
Shut off the engine and remove the red key. The immobilizer indicator light should start to blink after 30 seconds.
Insert the red key into the ignition and turn it to "ON", then "OFF" and then remove the key within 5 seconds.
Insert the black key into the ignition and turn it to "ON" within 5 seconds.
While the immobilizer indicator light is flashing, turn the black key to "OFF" and then remove the key.
Insert the next black key, turn it to "ON"
Wait for the immobilizer indicator light to stop flashing, turn it to "OFF"
If everything went OK, then you can use the both black key to start the engine.
Hope that helps
