Stutters at low rpm, clears above 3k
Hey all, new here, not to motorcycles, I was an FZ6 guy years back and am looking at a FZ1 to keep the F800GS company in the garage. The issue I'm having is the one I am looking at has a stuttering off idle and no power below 3k. I'm thinking coils, is there something else I should be looking at?
Sent from my SM-G965U using Tapatalk
Hi there
Your most likely correct in thinking it's a coil , had the same issue a while back, I just bought one coil and moved it across the cylinders until I found the faulty one,, you can also get water in the spark plug voids normally one no1 cylinder
