Pirelli Angel GT in 190/55 - will they fit
Dicko
Active Member
I run Pirelli Diablo Rosso III in 190 55 onthe rear, no issues. you will have to re-calibrate your speedo with a speedo healer as it does affect speedo readings. If you don't have one installed it will make it more accurate as the speedo is out stock anyway.
AEG
Thanks. I wasn't really thinking about the speedo reading, more for the fit under the tire hugger.
Lazy Libran
Active Member
Hmm.. The standard fitment is 190/50 so if I change the tyre to 190/55 - is this a mandatory step?
Are the service centre guys able to do this?
AEG
Made the switch half a year ago. No problems with anything. Do it and don't worry about it.
Same 4 mph off compared to gps as before
Lazy Libran
Active Member
Hmm... 4 mph equates to a little bit over 6 kmh here and in our awesome state - could mean a difference between a speeding fine or not...
AEG
The key is that it didn't change after the swap. So your right wrist issues remain as before [emoji2]
