v-petn
Hi all,
I'm having issues with my bike and not sure what's going on. I have the faulty FCE which is still on there. I;ve got BMC air filter, air box mod, gutted cat and slip on. AIS is still there but blocked off. Basically If I cruising at 4500rpm, I get this hesitation feeling. That I can deal with but the other issue I finding it's annoying and not sure if it's the throttle snatch issue or something else. I'll try and describe it as best I can. If I accelerate hard and then attempt to change gear, I get that massive abrup[t jolt. If I do it slowly then I get a slight hesitation and a lot of popping from the exhaust. Is it meant to do this?
Maybe I should check the error code (not sure how to do that). I'll probably remove the faulty FCE and see if that makes a difference...
