Xlerat
Looking for the torque on the front sprocket nut for the 01. Going with the 15T instead of the 16T, the bike really stalls off the line and takes a lot of clutch, no good...
thanks :iamwithstupid:
it just seems like the motor is a little weak from a stand still, esp. below 3000rpm, i just want a little more pop down low were it will matter. The bike only has 9000 miles on it, i don't believe it has carb issuse and besides it would be running like crap if it did.
Hi, thanks for that info however want to make sure if it also applies to 2nd gen FZ1 - the pics on that site you mention seem to indicate a previous model to mine and this makes me nervous that numbers might change.
Also any idea where to get the torque values for rear sprocket nuts?
Actually, to take it one step further :jaw drop: anyone know where to find all major tightning values for a 2007 FZ1 N?
Thanks in advance
Here you go. Straight from the Yamaha FZ1 Maintenance Manual:
Rear wheel sprocket nut M10 - 100 Nm (10.0 m·kg, 72 ft·lb)
Although to be honest I kind of remember a discussion about the rear wheel sprocket torque being too high as stated in the manual.You may want to only go about 70-80 Nm or so initially.
