[email protected]
Hello Lads,
My FZ1 (2008) has been in the garage for a couple of weeks and was running fine when I left it - started it today and its not firing on 4 cylinders ...
removed the plugs and they look perfect - (brown not black - not oily - gap good) cleaned with wire brush and WD40 on the Plug Leads.. still the same runninig
Its like a bike that has Pilot Jet in carb stuffed - when driving it chucks and breaks onto 4 cylinders over 4k rpm then on less revs its rough again
on Idle its cutting into 2/3 cylinders and back to 4
Does it sound like dirty Fuel ..? thinking of draining the tank and refueling - anyone have similar issues before ? is there a in line filter could be the problem or is the fuel injection system suspect ?
Thanks
Paul
Thanks
Paul
