MEAN 1
Wizard
Michelin Pilot Road 2CT , dual compound technology tyres . medium centre , soft side walls , long milage life & sticky sides . i will be replacing my OEM Pilot Road's , when my next tyre change is due ..
for our roads here in Greece the best tyre that ever put is dunlop quallifier
the warm very very quick with quick geometry!
Michelin Pilot Road 2CT is very good tyres but not as dunlop!!
i am heavily leaning toward the Dunlop RoadSmart on my next tyre change , thanks guys ..
I think "Best Tire" depends on a lot of factors.
Type of riding -
if you consistently ride hard, you'll be much happier with a tire of the supersport type. E.G. : Pirelli Corsa III / Rosso; Pilot Power / PP2CT; Metzeler M1 / M3; Dunlop Qualifier; Bridgestone BT016 / BT014 / BT002; Conti Race Attack.
If you mainly Commute : Michelin Pilot Road; Dunlop 221; Bridgestone BT056; Metzeler Z6; Avon Azaro; Conti Road Attack.
If you need a tire that is good for some miles, as well as being sticky enough for some spirited riding : Dunlop Roadsmart; Michelin Pilot Road2; Conti Street Attack
Also, it'll depend on the type of pavement that you're riding on. If the roads in your area are a smooth surface, you'll need a slightly stickier tire, if the roads are of the chip/seal variety, you can get away with a slightly harder tire as the pavement does a better job of gripping the tire.
I suppose it really boils down to personal preference and the type/style of riding you do. Each tire has its own properties that make it a good tire for different reasons. I wouldn't say that I've ever had any tire that was utter crap, and I've run just about everything out there, but I've used tires that didn't suit my style of riding very well.
