load resistor
hi guys,
how to connect the load resistors between the led flashmounts?
i noticed, i have 3 cable coming from the lights right know.
thanks for any help!
If you are running LED lights it negates the need for load resistors as it gives you the correct blink rate.
I have a set of Yamaha LEDs which came with pretty large load resistors.
To test them I put the hazard lights on and the indicators flashed once then died.
The load on the electrical system from the resistors was too much so I bought a dedicated LED flasher unit to replace the stock flasher unit and no such problems any more.
Here's one on Ebay:
Custom LED Electronic Motorcycle Blinker Flasher Relay | eBay
