WMU_BRONCO
Does anyone here have the Hole Shot AIS Removal Kit which uses billet aluminum caps instead of tapping and installing screws?
This kit is much easier than other kits that require tapping the ports and installing bolts.. ... but... A very similar kit can be found on eBay for even less money from TPO Parts
TPO Yamaha FZ1 Fazer 2001 - 2005 AIS Emissions Removal:eBay Motors (item 300351985293 end time Oct-05-09 06:58:39 PDT)
much easier to remove it is to remember where the hell you threw the AIS pump when you took it off.... odds are, you'll never have to put it back on... if there comes a day when your laws change, and you have to get emission tested... it's easy to play with the carbs for 5 minutes before you roll to the testing station....
Well that depends on whether they only do a sniffer test for emissions or also visually check the various components. In that case they would easily see that the AIS pump was missing.
I seriously doubt they would ever do that. Do you realize how many vehicles the techs would have to learn and be knowledgeable about what they are looking at?
If anything, they will do like they do cars now. If it passes, it passes, if it throws a code then they start digging deeper. If they find you have tampered with the emissions, then you are in trouble.
