FZ1inTX
Adminstrator
Having trouble with your Gen II? Engine light? Here's how to get to DIAG mode, clear it and check for existing codes.
Do you have the service manual? Do you know how to get into DIAG mode? If so, check d61 with the KILL SWITCH in the OFF/NO START position. When you hit d61, it will display any error codes and if there is more than one, it will change every two seconds. Write those down and consult the manual.
To do this, perform the following steps:
With the key in the ignition and the KILL switch in the NO START position:
Report back with any error codes you've found and we can tell you what they are and how to test the components or if you have the service manual, you can locate them there.
At this point, does the bike start? If the same clicking happens, and the engine light comes on, go back into DIAG mode, d61 and check to see if it is the same code(s). Report back.
- Press and hold both SELECT and RESET on the instrument cluster
- Turn the key to the ON position while still pressing the two buttons for 8 seconds. The display will change to "dl"
- Release the buttons then press both again for two seconds until you see "d01"
- Once there, use the reset button to move backward through the list or Select to move forward.
- Scroll to d61 and wait for 30 seconds to monitor any error codes. Write them down.
- To clear the codes, scroll up one to d62
- Put the KILL switch in the RUN position and wait 5 seconds.
- Put the KILL switch into the NO START position
- Scroll to d61 and verify the error codes are erased.
