Gen II Diagnostic Mode - Err 30
I had my tank off yesterday to fit some heated grips and associated wiring (coming into winter in Sydney).
When I went to use the bike, the check engine light stays on.
Following the excellent instructions here;
http://www.998cc.org/forum/gen-ii-tech/17481-gen-ii-diagnostic-mode.html
* At D61 the error code value 30 the first time - I waited but no other error codes came up.
* I went to d62 to clear the error, value = 1, but could see no change.
* returned to D61 and value is now 0.
* returned to d62 value is still 1.
* started bike and repeated. Check Engine light is still on.
* returned to D61 value is still 0.
What is error code 30? (I am thinking that maybe I didn't connect the air temp sensor).
Any idea why the Check Engine light is on, but d61 shows value 0?
Cheers,
Darryl
Look's like you have code 30 - Lean angle sensor (latch up detected)
I assume this is a tip over switch ??
01 - Throttle position sensor signal
02 - Atmospheric pressure Displays the atmospheric
03 - Intake air pressure Displays the cylinder-#1
05 - Intake air temperature Displays the intake air temperature.
06 - Coolant temperature Displays the coolant temperature.
07 - Vehicle speed pulse 0–999 Check that the number
08 - Lean angle sensor Remove the lean angle
09 - Fuel system voltage
20 - Sidestand switch Set ON/OFF the sidestand
21 - Neutral switch Set ON/OFF the neutral
30 - Cylinder-#1 ignition coil Actuates the cylinder-#1 ignition
31 - Cylinder-#2 ignition coil Actuates the cylinder-#2 ignition
32 - Cylinder-#3 ignition coil Actuates the cylinder-#3 ignition
33 - Cylinder-#4 ignition coil Actuates the cylinder-#4 ignition
36 - Injector #1 Actuates the injector #1 five
37 - Injector #2 Actuates the injector #2 five
38 - Injector #3 Actuates the injector #3 five
39 - Injector #4 Actuates the injector #4 five
48 - Air induction system solenoid
50 - Fuel injection system relay Actuates the fuel injection
51 - Radiator fan motor relay Actuates the radiator fan
52 - Headlight relay Actuates the headlight relay
53 - Exup servo motor Actuate the servo motor turns
56 - Sub-throttle servo motor Actuate the servo motor turns
60 - EEPROM fault cylinder No
61 - Malfunction history code
62 - Malfunction history code
63 - Malfunction code reinstate
And here are the ECU error codes
11 - Cylinder identification sensor
12 - Crankshaft position sensor
13 - Intake air pressure sensor
14 - Intake air pressure sensor hose line
15 - Throttle position sensor (open or short circuit)
16 - Throttle position sensor (stuck)
17 - EXUP servo motor potention circuit
18 - EXUP servo motor (stuck)
19 - Sidestand switch (open circuit in the
20 - Intake air pressure sensor or atmospheric
21 - Coolant temperature sensor
22 - Intake air temperature sensor
23 - Atmospheric pressure sensor
24 - O2 sensor No normal signal is received from the O2 sensor.
33 - Cylinder-#1 ignition coil
34 - Cylinder-#2 ignition coil
35 - Cylinder-#3 ignition coil
36 - Cylinder-#4 ignition coil
39 - Injector (open circuit)
41 - Lean angle sensor (open or short-circuit)
42 - Speed sensor No normal signals are received from the speed sensor.
43 - Fuel system voltage (monitoring voltage)
44 - Error in writing the amount of CO adjustment
46 - Vehicle system power supply
47 - Sub-throttle servo motor potention (open
48 - Monitor the operation of the sensors and
48 - Sub-throttle servo motor (lock)
50 - ECU internal malfunction (memory check error)
Maybe some people use it as a tip over switch - for me, I guess when they designed the FZ1 they didn't expect for someone with my hektik skillz to be riding it. :bs2: :bs2:
Thanks for the list, I'll go through the diagnostic mode again this evening and check that there are no other codes, because I assume that the tip switch should clear and not return when I reset D62.
If not, any idea where the tip over switch would be located so I can check the connector...
Cheers,
Darryl
Just to close this off -
I guess between the time I checked in the car park at work, and caught the lift 3 floors, I mixed up what error code I was reading...
I had a suspicion that I had done just that, and was confusing Value 20 with Value 30...
It was the connector on top of the airbox to the Temp Sensor... about a 30 minute fix...
Alas - seems my Stoner-esque riding was not the cause...
Still don't know why after I reset the codes, the light stayed on but no value showed up again in D61...
Thanks everyone for your input...
Cheers,
Darryl
