daniels
I have a 2001 FZ1 and the carbs seem to be leaking but I have no idea from where. The bottom of all of the carbs are wet with gas and it drips on the motor and runs down the side and onto the floor.
Any ideas?
Any ideas?
Any ideas?
I have an idea. Pull the seat, tank, and covers off and grab a flashlight.
It's probably one of your float are stuck. There are times when you can tap on the bottom of the carbs with the end of a screwdriver and dislodge them but there's no guarantee that it won't happen again. You may just have to pull them and clean them manually. Also, if you do tap on them and dislodge the stuck float or floats, add a dose of Seafoam to your gas for two consectutive tanks and see if it clears up whatever is causing them to stick. Was the bike sitting for any extended period of time? If so, it may have gummed up the floats.
It actually appears that all of the carbs are leaking from around the bowl seal. It's strange that all 4 would be doing this but I'll take a look again tonight. I keep wiping the carbs clean and trying to trace the fuel.
Don't let that illusion fool you. Many times, the leak is higher up or coming from just one place and it seeps to the areas of least resistance, making it appear that the leak is coming from somewhere that it isn't.
Did you recently get the bike, or have you had it for a while?
Did the bike sit around for a while? Could be that the rubber gaskets that seal the bowls to the main carb bodies are bad. Another possible issue is loose drain bolts on the bowls themselves.
