Mr scotto
Well the story starts with two seperate refuels,think i got the dregs from the tanks as the bowsers lost pump pressure and we've had lots of rain in theses parts.the following issue has only happened a few times at operating temp,bike starts fine then while idleing seams to drop to 3 cylinders-raise revs by 1-2k for a few seconds and things get better but this now gets the better of me.I think electrical but plugs changed 9k ago and tend to think this would be there constant or under load if this.Next is fuel, injector cleaner from auto shop in the tank and an excuse for a ride,then thinking i have read somewhere about tps problems i raise idle by about 200 revs(mistake,now i have done two things)bike has not missed a beat for 2 days but seems be poping out the exhaust a little more than normal,temp maybe running 2-3c above what i would expect unless being flogged seams to be ok.next step is on the net and off to fz1 forum for a bit of a search.
1.injectors may need to be removed and professionally cleaned.
2.fuel filter may be blocked(is this a filter or strainer?).
3.when removing fuel pump/filter are the gaskets reusable.
4.fuel tank will be removed and cleaned to the best of my ability.
Aftermarket pipe and no ecu upgrades on the bike.
So if anybody has any tips can i have them please.
