Mr Baytchos
Icon Compound Jacket Stealth 3XL: $175 obo
This Jacket is great and the only reason I'm getting rid of it is because I have a liner-less version for the summer and was given a full leather jacket that I'm going to use in the colder months. This jacket was involved in my crash into the ditch but I had it sent out to a leather specialist to clean and oil it and the only sign it was in a crash is a few scratches on the back plastic plates. Worn for only one season. Here is the description per Rezvilla:
Icon Compound Jacket - RevZilla
Castle Ladies Turbine Black Size 8: $100 obo
My Wife bought this jacket and wore it less than 5 times. It is now too small for her and she can't wear it. No issues at all with this jacket it is literally like new. Here is the info on this jacket per Castle:
The Compound jacket by Icon is what we refer to as a Hybrid style. Half leather, half textile, fully awesome. The chassis is constructed largely of high- tenacity textiles for both reduced weight and ease of movement. 1.2- 1.4mm cowhide is used in all of the major impact areas. The upper back area is equipped with articulating plastic plates to increase the jacket’s protective envelope. Ratchet adjuster straps on the waist allow for rapid fitment options. Multiple air ducts and Fighter Mesh inserts pump cooling air into the jacket for maximum comfort. Finally, a removable insulated full-length liner is included should the outside air temperature drop to unacceptable levels. If your question is the ease of textile, with the protection of leather - the Compound jacket is your answer.
ICON SPORT FIT
DURABLE TEXTILE AND 1.2-1.4MM LEATHER CHASSIS
REMOVABLE ICON FIELD ARMOR TM ELBOW & SHOULDER IMPACT PROTECTORS
REMOVABLE ICON DUAL-DENSITY FOAM BACK PAD
ARTICULATING EXTERNAL INJECTION MOLDED PLASTIC BACK PLATE
RATCHET WAIST ADJUSTER STRAPS
GATHERED STRETCH PANELS FOR COMFORT AND FLEXIBILITY
REMOVABLE INSULATED WIND RESISTANT VEST LINER
UPGRADABLE TO STRYKER CE BACK PROTECTOR
Ladies Turbine Mototrcycle JacketWomen’s specific pattern for superior fit
600D Hitena® nylon shell incorporates Perma-Flow vented panels in front, back and arms
Pre-curved and rotated sleeves
Removable full sleeved insulated liner with exclusive bonded membrane technology creating windproof, waterproof and breathable performance
6 easy access pockets including interior media pocket with cord opening
Comfort-Flow™ mesh lined shell for increased comfort
Soft-Touch micro-fiber lined collar and cuffs
Snap adjustable waist, biceps and forearms
Removable impact absorbing molded armor in elbows and shoulders
Removable foam back pad
360° reflective elements
Replacement armor available
